i know that most people might have came across this problem b4 but i just need an answer or a way round it.
when i convert .avi files to mpg1 it seems to lose quality, is this normal and is there a way round it?
also what is the difference between .asf files and .avi files please?
thanks in advance
Whenever you recode a file you will loose quality. The trick is to loose as litle as possible.
Originally Posted by akeem
Advice needed for converting MJPEG from Canon camera
By cdowdy in forum Video ConversionReplies: 5Last Post: 4th Jun 2016, 12:26 -
Help needed Converting to AVCHD to play on Panasonic TV
By LOWTECH in forum Video ConversionReplies: 8Last Post: 31st Aug 2011, 12:52 -
help needed converting and editing an flv please
By Witzend in forum Newbie / General discussionsReplies: 6Last Post: 23rd Aug 2011, 15:04 -
trouble converting/xb360 essential settings needed
By Captain Slow in forum Newbie / General discussionsReplies: 8Last Post: 17th May 2011, 19:14 -
Help converting YUV420 to RGB565 needed
By cheetahace in forum ProgrammingReplies: 3Last Post: 18th Apr 2008, 02:15
