I have some mp3s with a bitrate of 128, and a program that I can change the bitrates to what ever i want. My question is, if I change the bitrates on them to 192, will the sound quality actually increase? I also have a few that are a 96 bitrate.....and sound eh......if i do the same for them will they become cd quality?
Results 1 to 9 of 9
What We Do In Life, Echoes In Eternity....
GuestGuest
Wouldn't you need to expand them into .wav files, then recompress them. I think you might lose some quality in the translation.
If you take a rotting piece of fruit and pop it into the microwave, will you end up with a delicious rump roast?
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
the short answer is no..
as long as the mp3 was made from the original source (cd/dvd), then it should sound fine.
its when you start dealing with generations that you start having problems with quality (cd/mp3/cd-r/mp3) -
Nope. Compressing a compressed file is noever a way to increase quality. You'd have to re-rip the CD for better quality than you have now.
Ok thanx for all your answers.....guess I'll have to rerip them then.....thanx again
What We Do In Life, Echoes In Eternity.... -
Or if you want quality that MP3 can't touch, try Vorbis:
www.vorbis.com
It's free!
Cobra -
GuestGuest
If you don't have any luck you can always revert to :
http://www.8trackheaven.com/cdconverter.html
Change audio in mkv from mp3 to ac3
By gauche in forum Newbie / General discussionsReplies: 2Last Post: 19th Jun 2011, 06:05 -
Want to change a bunch of mp3 files to smaller bitrate
By happydog500 in forum AudioReplies: 6Last Post: 11th Aug 2009, 13:08 -
Best FREE software to change a WMA file to an MP3??
By UmmAddan in forum AudioReplies: 17Last Post: 20th Jun 2009, 18:52 -
Encoding MP3 causes the sample length to CHANGE?
By Colmino in forum AudioReplies: 1Last Post: 26th Nov 2007, 21:00 -
How can i change an mp3 to a wav?
By pondleaping in forum AudioReplies: 7Last Post: 28th Jul 2007, 03:09
