I've been time- and space-shifting our DVDs so I can keep the kids in their seats during long flights.
I have some older promo videos which consist of a .bin & .cue pair.
I would like to transcode (and crunch down) to much smaller DiVX .avi or .mp4 but I can't find any tool(s) which does this, despite searching here, at VersionTracker, and the 'net at large.
What am I missing?
Results 1 to 15 of 15
Good answer.
I've installed it, but when I select a .bin file to transcode it sends the following to the Terminal:
Sadly, using DarwinPorts to install libvorbis fails. Grrr. Close, but no cigar.Code:% pbpaste | sh Encoding started on Thu Apr 8 15:53:20 PDT 2004 dyld: /usr/bin/mencoder can't open library: /usr/local/lib/libvorbis.0.dylib (No such file or directory, errno = 2) sh: line 1: 8797 Trace/BPT trap /usr/bin/mencoder /foo/KVCD.bin -oac mp3lame -lameopts cbr:br=128:vol=0 -aid 0 -ovc lavc -sws 0 -lavcopts vcodec=mpeg4:vbitrate=843:keyint=240:vqmin=2:vqmax=15 -ofps 23.976 -vop scale=480:320,crop=352:192:0:24 -o /foo/movie.avi
Yes, all three of them, from the links provided in the pre-installer.
Most frustrating. -
As below, so above and beyond, I imagine
drawn outside the lines of reason.
Push the envelope. Watch it bend.
Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind. -
well why pull your hair out trying to get something flawed working when i just gave u an EASY workaround? is it worth being that hardheaded about it? just convert the bin to mpeg and it will be easy sailing.
Bilestyle is right. Use VCDToolsX. Tgpo (what a great guy!) has it for download here http://homepage.mac.com/tgpo/prog/vcdtoolsX.sit and use the vcdxrip button to get the mpeg out. Then select the mpeg in ffmpegx for conversion. Galactica is right, it will do a great job, but helping it out with a good format won't hurt.
I didn't realize I was pulling my own hair. Ouch!!
Thank you both for continuing to hit me with those clue bats.
I'm extracting the .mpg from the .bin now. Thanks. -
Works well, but seemingly only with single self-contained .bin files.
With a release which consists of several .bin files I note that vcdXrip does the extraction, which VLC can read (but not random access through), but QuickTime Player doesn't recognize as a valid movie.
Am I missing something, or is there a way of concatenating the .bin files before running them through vcdXrip? -
Follow-up on the last post, before a mistake of mine misleads others:
I think part of the problem is a poor source. I notice that VLC can't random-access through this video either. So that's not a problem of the extraction process.
My question then stands thus: "how do I combine .bin files so that I can extract multiple ones (-a, -b, -c, etc.) into one mpeg"? -
when did i say that?! you just asked what app you needed for the job, and i told youOriginally Posted by SinceEBCDIC
you should extract the .mpeg's out of the bins. takes only a couple of min. as per joining bins to extract one large mpeg, it would take the same amount of time as extracting all the bins and joining to make one large mpeg [besides, i dont think you can join bin files!!!]
also, upon creating the large mpeg file, demux and remux it again to remove any time code errors upon joining. this will ensure that any encoding apps dont choke up when they get to the segment points. -
repair permissions. Startup from your OSX cd, get into your DiskUtility and repair your permissions, this often solves the problem. Also mpegtx can join the mpegs you extract. http://www.versiontracker.com/dyn/moreinfo/macosx/15987
issues with playing .avi & .mp4
By Betadog in forum Newbie / General discussionsReplies: 20Last Post: 22nd May 2012, 02:50 -
Lossless transcoding of AVCHD to mp4.
By yardline in forum MacReplies: 4Last Post: 7th Jan 2012, 16:59 -
Solutions for transcoding (and clipping) MP4<->AVI
By urymf in forum Video ConversionReplies: 0Last Post: 31st Aug 2011, 09:26 -
How to Combine MP4 Clips and then to WMV & AVI
By gonwk in forum Video ConversionReplies: 3Last Post: 2nd Mar 2010, 09:35 -
Merge two AVI's & SRT's into one MP4
By vassie in forum Video ConversionReplies: 6Last Post: 18th Sep 2009, 05:00
