That is what I have: a marriage VHS tape somehow recorded that, in my SONY VCR I can hear the original soundtrack (screams, laughts, etc) when played in HI-FI mode, an another soundtrack (edited, background music) when played in NORMAL mode... so, there are 2 audio streams in it... I dont know if audio in left is differente from right or there is something more complicated in it... I never saw such kind of tape before...
What I want: convert that VHS (with both audio streams) to MPEG (dvd compliant) and burn it in DVD-R media. I will create a simple menu in Ulead DVD MovieFactory in order to choose one number to play the video with original (non-edited) audio, an another number to play the the same video with the edited audio...
the movie is 2 hours long so I can put it only once in DVD-R media...
The software I have is Virtualdub, TMPGEnc, Ulead DVDMovieFactory.
I also have DVD XPress hardware and ATI AIW128Pro video card.
Do anyone have a tip or idea how I start that project using the softs and hardware I have?
Thanks in advance. From Brazil.
Fred©
It's funny, but I've thinking about it and I think it can be done by capturing second track at second time or by setting up VCR to play one track on each channel. The problem of second choice is you will lose stereo sound of hi-fi track.
You can try this.
In Portuguese:
Engraçado que eu estava pensando nisso há um tempo. Eu acho que vc pode capturar em duas etapas, uma com um áudio e depois só o outro áudio ou setar o VCR para tocar cada trilha num canal diferente. O problema da segunda alternativa é que vc vai perder o som estéreo do hi-fi.
Tenta aí e me fala o que vc achou. -
the problem is: the second VHS capture maybe not exactly as the first one, because of VCR delay when pulling the play button, human being time delay error, differences from the beggining of tape in both tries after rewinding, etc...
in portuguese:
cara, tenho receio de que, de alguma forma, não consiga sincronizar o início da gravação de cada canal, por motivo de atraso do VCR ao apertar o botão de play, erro humano, etc. Se o início de ambas as gravações não forem PRECISAS, posso ter erro de sincronia labial... -
That's true, but he can adjust syncronism after. I've done a similar adjustment before.
Can Vob2MPG convert audio streams?
By ThejafF23 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 13th Dec 2011, 13:07 -
VHS capturing audio issues
By Cyberrock in forum Capturing and VCRReplies: 4Last Post: 26th Jul 2010, 11:14 -
Swapping the Audio Streams in a MKV in order to then convert
By JP585 in forum Video ConversionReplies: 2Last Post: 22nd Dec 2008, 05:26 -
Simplest way to convert and join avi's with different audio streams??
By Lolipop Jones in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2008, 12:25 -
restore and capturing VHS to convert to DVD
By WeatherSTAR-XL in forum RestorationReplies: 4Last Post: 16th Jun 2007, 19:37
