Hey, i recently bought a portable dvd player. I have been unable to open it cause im currently a bit busy, but i have a question. I usually burn my dvd's with 4:3 view, but the dvd player says 16:9. I use 4:3 because thats the auto set on TMPGenc and my home dvd players works fine with it. Here are my 2 questions: What will happen when i play my dvds with are 4:3 on the 16:9 portable 7 inch dvd player? I now have began to burn 16:9 and noticed that they are bit squished so under video arange method in tmgenc i make it center (custom) size and choose my own size so that it looks fine, but the aspect ratio is still on 16:9 will this affect anything?
Any light on these topics would be greatly appreciated
Melovecomp
They'll be stretched horizontally if you display them full screen. There are many ways around it - zoom, black bars left and right, stretch only the left/right side... You'll know which ones your player supports when you open it.What will happen when i play my dvds with are 4:3 on the 16:9 portable 7 inch dvd player?
Not sure what you do here, but if you want to make 16:9 videos they have to be "stretched" vertically and flagged as 16:9. What your player will do then is stretch them horizontally so that they display properly on 16:9 screen (on a 4:3 will squeeze the image and add bars top and bottom for letterboxed mode).I now have began to burn 16:9 and noticed that they are bit squished so under video arange method in tmgenc i make it center (custom) size and choose my own size so that it looks fine, but the aspect ratio is still on 16:9 will this affect anything?
DVD Ripping...DVDShrink, DVD Fab question...
By nharikrishna in forum DVD RippingReplies: 9Last Post: 28th Feb 2011, 06:08 -
Regional Code Question - Insignia DVD player - can't play DVD I ordered..
By LadyDriver22 in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2010, 13:08 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43 -
question about difference between TMPGEnc DVD Author and DVD Flick
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 21:06 -
question about multiple titles on DVD using DVD Flick
By jimdagys in forum Newbie / General discussionsReplies: 1Last Post: 4th Mar 2008, 21:47
