Hi there, i have a dvdrw dual drive in my laptop, its is a 2 speed device. Can you use a 4 speed disc in a 2 speed device?
When i use a 2 speed -R disc i can burn a dvd image to the disc without problems, when i use a +R 4 speed disc it fails when on lead out? I am using the latest version on nero to burn the images to the discs.
Also, Is it true that dvd writers will have problems with certain brands of discs? could it be this that is causing the problem. Although i am using the same brand of + and - r disc. If so how does one know what brands are compatible, not many places near me sell single discs, trial and error could work out to be quite expensive...
cheers
chris
go to the website of your dvd burner and see if they have an update to burn 4x media. you won't be able to burn at 4x, but you should be able to burn the 4x media at the speed of your burner 2x(2.4x)? media is very important, some dvd players and burners, don't like one media, but will work great with another
Burning DVD issue with Sony HDR CX 100 (PMB software)
By jungleeravana in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 25th May 2010, 23:43 -
Tivo to DVD Burning Issue
By jdogg2603 in forum Newbie / General discussionsReplies: 21Last Post: 7th Jan 2010, 06:27 -
burning issue
By jfree in forum Newbie / General discussionsReplies: 6Last Post: 20th Nov 2008, 02:06 -
dvd architect burning issue
By merray in forum Authoring (DVD)Replies: 1Last Post: 8th Nov 2008, 01:38 -
I/O Error when burning DVD's/Hardware or software issue?
By alegator in forum ComputerReplies: 15Last Post: 22nd May 2008, 00:20
