Hi,
I've got an .asf file that I am about to convert to DVD using TMPEnc. Only problem is that I don't know what framerate it is, so don't know whether to do it in NTSC or PAL. I usually just have a look on Virtual Dub, however the version that I have won't allow me to open .asf files. I believe that earlier versions of Virtual Dub do still support this format, however I've searched hi and low and can't find any versions that are early enough. Is there another way of finding out the framerate of this file, or does anyone know where I can get hold of an early version of Virtual Dub, or do I just guess and see how it turns outs?
Any help would be much appreciated!
Mark.
http://www.google.ca/search?q=virtualdub+asf&ie=UTF-8&oe=UTF-8&hl=en&meta=
or did you look in tools at the left ?
https://www.videohelp.com/tools?tool=399"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
How do I find out the framerate of a Quicktime MOV video file?
By Dr.Rock in forum Video ConversionReplies: 3Last Post: 10th Sep 2012, 19:37 -
How can I convert ASF file?
By QuattroNN in forum Newbie / General discussionsReplies: 2Last Post: 29th Apr 2011, 14:11 -
.asf file will not open
By powrslave in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2011, 11:56 -
How do I determine the framerate of an FLV file??
By lurky in forum Video ConversionReplies: 2Last Post: 13th Aug 2008, 01:13 -
help on .asf file conversion
By fabpozzi in forum Video ConversionReplies: 5Last Post: 23rd Jun 2008, 20:13
