Using DC10+, I think it stores the video as MJPEG file (correct me if I'm wrong). How long a full screen video can be stored in a 2GB file?
...it depends on what MJPEG compression you use. I believe the max you can set on DC10+ is 6MB/sec. If you're using that, you can do the math.
Does zipped video file take less time to upload than unzipped file does?
By coody in forum Video Streaming DownloadingReplies: 3Last Post: 12th May 2011, 11:22 -
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 13:04 -
Which one is better? Shrink 4GB movie to 2GB MPG or 2GB Xvid?
By volam in forum Video ConversionReplies: 4Last Post: 13th Jun 2009, 02:20 -
Converting and splitting 2GB MPG file
By mohalfares in forum Video ConversionReplies: 3Last Post: 2nd Sep 2008, 13:47 -
what is the 'DSL' file that seems to appear from time to time on DVD's?
By rotuts in forum MacReplies: 6Last Post: 24th Aug 2008, 15:08
