go to this link i posted pictures of my problem. any help would be great
http://boardsus.playstation.com/playstation/board/message?board.id=general&message.id=567143&page=1
Looks to me like you tried to burn at a speed you system/CD writer could not handle (48X). Slow down the burn speed and try again.
Big Government is Big Business.. just without a product and at twice the price... after all if the opposite of pro is con then wouldn’t the opposite of progress be congress? -
babygirl2000 wrote: your driver is defected
you wrote: how do i fix it?
babygirl2000 wrote: u get a new driver that isnt defected.
classic!
just out of curosity.. did you update the driver? -
no how do i do thatOriginally Posted by galactica
my stock dell burner broke. i got dell to replace it a guy came over and it took him 3 mins to install the new burner so he didnt update anything
my old drive was 8x the new one is 48x i might have to update the dive -
the buffer underrun happens because your system cannot supply the burner with data quick enough. are you by any chance creating an audio cd from MP3 files?
you can only burn it as fast as your pc can get it off the hard drive. without knowing more about your pc i can't say what that speed will be. use succesively lower burn speeds until you find one that works. -
what do u want to know and ill post the infoOriginally Posted by flaninacupboard
i realy want to burn at 48x seed -
ok, well a) are you burning audio cd's made from MP3's?
b) what make/speed is your hard drive?
c) what else are you doing with your PC at the same time?
d) what speed is your processor?
Avi burning problems
By blitzen in forum Authoring (DVD)Replies: 3Last Post: 1st Mar 2011, 12:09 -
Dl burning problems
By calanda in forum DVD RippingReplies: 13Last Post: 13th Apr 2010, 23:25 -
TYG02 burning problems.
By videobread in forum MediaReplies: 2Last Post: 11th Oct 2009, 12:51 -
DVD burning problems
By Tbag in forum ComputerReplies: 13Last Post: 3rd Sep 2008, 15:55 -
DL problems after successful burning
By m-man in forum Authoring (DVD)Replies: 7Last Post: 9th Jul 2007, 19:53
