  1. Ok, i'm still kinda new to the converting from one file to another, and need some help. I want to convert a bunch of .mp4 files over to DVD, and fit about 24 on one DVD +/- R and need some help, namely, converting the files (preferably a click and drag solution, and even batch encoding all the files) and also making a DVD with a chapters menu would be nice too.
    Thanks in advance.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    You need to do some reading.
    The links BJ_M gave you will get you there.
    Out of interest, why the need to get 24 on 1 DVD ? The quality will be pretty ordinary IMO. Unless you have the series, 24, of course - then it would make sense.
    If in doubt, Google it.
