I am using DVD Rebuilder 0.31, and CCE SP 2.67
two problems, it creates a project with like 30 different items to encode, all very short, takes only a few seconds to encode each...
after it's done encoding(well, whatever the hell it actually encoded), and I go to reauthor, I get
"run-time error '75':
Path/File access error"
anyone kno what's going on?
Results 1 to 9 of 9
It is highly recommended that you post at Doom9's forum which is home to DVD Rebuilder.
Here's the appropriate thread for you to post in.
DVD Rebuilder (One-Click Beta) Bug Reports - v0.30+
In fact, do a search. Someone probably posted a similar problem like yours over there. -
I also have to wait 5 days... However my problem is that I want to "convert" movies from 2.35 to 1.77..
About your problem, is CCE starting up at all? I'm using 0,31 and SP2.50.
If you choose to do it step by step instead of "one click" mode. When do you get your error msg? -
I've actually fixed the problem. I wasn't using ECL...
The file/path access error... it seems that rebuilder wants write access to the source directory, so I just moved all the files from the iso to a folder on the hard drive, and it now works like a charm.
I can hardly wait till he enables support for multi angle and interleaving...
what is VBR Bias and Quality precision? I've never messed with those settings before... -
^^I too would like to know about these settings?
The bias setting is by default 30 and the lower the value, the more variable the encoding bitrate.. From what I have seen so far, 20 is the lowest that you should consider using.
As for the Prec. Quality - I haven't got a clue about that.
Any help explaining what to use, and which is "best" would be grate?
I plan on using 3 pass VBR.
Does each pass double the time?TheGame7 - "I am 'The Game' because I am that damn good!" -
each pass takes about the same amount of time...
so if 1 pass takes 5 minutes
2 pass = 10 minutes
3 pass = 15 minutes
and so on. -
i really dont know about bias, but about the precision quality as far as i know, lower values are for action movies or with lot of motion, but increase the edge noise around objects ( like flying mosquitos). I dont the cons for higher values.
I hope this help. -
^^So what setting is the "norm"?
15?TheGame7 - "I am 'The Game' because I am that damn good!"
DVD Rebuilder overflow
By RickyPinxt in forum Video ConversionReplies: 14Last Post: 27th Apr 2011, 14:43 -
DVD in BD Rebuilder!!!
By fjmr in forum Blu-ray RippingReplies: 3Last Post: 18th Aug 2009, 10:22 -
dvd rebuilder
By dvd1304 in forum Newbie / General discussionsReplies: 2Last Post: 20th Jul 2009, 12:31 -
DVD Rebuilder (free)
By maja_the_bee in forum DVD RippingReplies: 1Last Post: 27th Jul 2008, 10:12 -
problem with dvd rebuilder!
By jonkiller in forum DVD RippingReplies: 1Last Post: 2nd Aug 2007, 08:58
