Okay, I've recorded 70 wav files to dvd. About 8 lps worth. This dvd will play on my computer's creative software player, but it won't play on my dvd player. What do I need to do to get it to work on a dvd player? I'm using NERO to burn, and it has DVD options.
heres a guide that will do that
https://www.videohelp.com/forum/userguides/193049.php -
Thanks for the guides. I have another question: My wav files are all in 24 bit, 44 khz. Is it going to be a problem converting them to 48 khz, which seems to be what DVD requires? I sure hope I won't be forced to re-record, re-master those 8 lps worth of songs just because they weren't originally done in 48 khz. If so, what tools do I need to convert a 44khz wav to 48 khz?
you should be able to convert your existing files. i think audacity, a totally free audio editor, should be able to do it.
http://audacity.sourceforge.netSwim with me
And we'll escape
All the trouble
Of the present age
Finally free
HDD/DVD recoder doesn't record or play dvds
By maybell in forum DVD & Blu-ray RecordersReplies: 5Last Post: 1st Mar 2010, 14:09 -
Will 720p record on standard dvd and play in HD on Blueray?
By jimdevo in forum Newbie / General discussionsReplies: 15Last Post: 14th Feb 2010, 14:15 -
Stand Alone DVD record Won't Play on PC?
By rkersh409 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 26th Jan 2010, 13:23 -
If I record in Widescreen 16:9, how will a DVD play on a Standard 4:3 TV?
By syberkill in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 3rd Jun 2008, 11:03 -
HELP: Looking for a GOOD DVD VHS combo - Don't need to record just play...
By UNOWEN in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Sep 2007, 12:24
