Hi
I am having trouble exporting my finished video from Premiere to get it ready to burn.
The original files are in DV format (Canopus codec) from a total size of approx 4.2GB.
I have made my changes, etc and now want to re-save it as an mpeg and burn it to DVD, but my problem is now I can't get the same quality as the original file. for some reason when I try to make my file fit on one DVD, the bitrate goes down to around 2000 instead of approx 5900-6500 that the original was in.
I have tried using an mpeg audio option, as well as wav, but I just can't seem to get the file to fit on one DVD without dropping the quality to an unacceptable amount. It's weird cause the new video I have made is 20min shorter than the original!!!
What am I doing wrong??
Well, you are trying to put a video on a DVD without allowing for how long the video is. Remember, file size is a function of bitrate x time. So if you if you want a good estimate of what your file size should be, use a bit rate calculator.
Hello. -
That's the weird thing, it SHOULD be around the 5700 mark. but I can't seem to get it like that.
I have also tried saving the file as an AVI and then converting in TMPENC and same issue occurs, I do not understand why, doesn't make sense.
The file is approx 1hour and 30min -
Cool, will try the above.
Any other solutions? I got a long weekend coming up so I am gonna be trying to get this right during this time, so I wanna be armed with as many options as I can get!!! -
Export it from premiere as Microsoft AVI, that is a uncompressed format, so make sure you have room, it will be big. Uncompressed = no quality loss.I am having trouble exporting my finished video from Premiere to get it ready to burn.
Then use TMPGEnc Plus to make it a DVD compliant MPEG-2, you can change your bitrate in TMPGEnc Plus.
For me anyway, this is hands down the best method. I don't like adobe's MPEG encoder, I think the quality is poor...it's poorer than TMPGEnc's!
Having trouble getting mkv to mpeg2 with FAVC
By Onceler2 in forum Video ConversionReplies: 1Last Post: 31st Jul 2011, 18:14 -
Trouble Converting TS to MPEG
By Somebody2 in forum Video ConversionReplies: 2Last Post: 14th Jul 2010, 19:30 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 15:18 -
Trouble converting(demuxing)
By VJep in forum Video ConversionReplies: 5Last Post: 25th Dec 2008, 00:43 -
Trouble when saving MPEG2 Ulead VideoStudio 10
By faramith in forum Video ConversionReplies: 3Last Post: 13th May 2007, 10:17
