I bought a pacific digital dvd +r burner ( x4 ) speed and installed the full version of nero 6.
I can only seem to burn at 2.4 speed though.
I have gone through every setting I know of and cant seem to find a way to fix this.
I dont even use nero to burn usually - I use dvd labs burning tool, but it seems to be stuck on 2.4 too.
I am using tdk X4 speed +r media.
any fixes for this?
Look for a firmware upgrade for your burner. They are constantly checking out new media and updating the firmware for the speeds, performance and compatibility with different media.......
Check to see if your burner is in DMA mode.
http://www.ati.com/support/faq/winxp/winxpconfigenabledma.html
Weird DVD Burner issue
By Noahtuck in forum ComputerReplies: 1Last Post: 8th Nov 2011, 19:52 -
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 23:53 -
K-lite issue then mp4 issue
By Arch3type in forum Software PlayingReplies: 0Last Post: 15th Dec 2010, 11:57 -
Double Layer Issue That Is Beyond Bizzare..I think I killed the burner
By mrjoelabs in forum DVD RippingReplies: 5Last Post: 1st Sep 2010, 09:49 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15
