Please can anyone advice me on how to improve the sound quality of my ripped DivX movies.
I've ripped two movies so far and the sound that comes out are just so soft that I have to turn my volume up to almost three quarters in order to hear any sound.
I am using Dr DivX to rip my movies.
Any suggestions will be greatly apperciated!
What do you mean by "ripped"? It usuall means taking a movie directly from a DVD.
If you downloaded it from the Internet, then you did just that. Anyway, see if you can extract the audio from the movie with Virtual Dub mod. Then use Gold Wave to increase the volume. Save the audio file under a new file name, then use Virtual Dub again to add it back to the DivX file, and save it under a new file name.Hello.
convert avi with subtitle files (.sub & .idx) into .m4v with soft subs?
By The Nemesis in forum Video ConversionReplies: 1Last Post: 6th Mar 2011, 20:40 -
AVI to DVD with soft subtitle and menu with AVI2DVD
By kschang in forum User guidesReplies: 95Last Post: 7th Feb 2011, 16:55 -
How to Get an .avi file with Soft-Coded (On/Off) Subtitles
By Spiralagnus in forum SubtitleReplies: 3Last Post: 20th Nov 2010, 14:00 -
[HELP][ANIME] MKV (H.264 + AAC) to AVI (PS3 - Compatible) with soft-subs.
By mooshimuushi in forum Newbie / General discussionsReplies: 4Last Post: 21st Aug 2010, 01:42 -
How to convert MKV with soft subs to AVI using DVDFab 6.x
By Shilar in forum User guidesReplies: 0Last Post: 28th Aug 2009, 09:15
