I have been using TMPGEnc for a long time and I didn't have any problems till now. I try to convert an avi file into Mpeg. But TmpegEnc does not support the audio format of the avi files when I try to convert them. It seems that I don't have the proper Codec. When I click on the Audio properties of the avi file it says "Mpeg Layer-3"! I can listen to MP3s...but what does that mean? Does anbody know where I can get this codec so I can convert those avi-files? Thanx!
If your avi files is a DivX...
It could have been encoded with the new version of DivX.
Try installing DivX 4.02 (which is backward compatible with older versions of DivX) and see if TMPEnc recognizes the audio.
http://www.divx.com/
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I have the same problem, i can play mp3 and divx files via m/soft media player, but most encoders will not recognise the audio stream within the divx.avi file, so i have split the audio and video out into seperate files, and then use tpmg to convert to mpeg format
I have installed the divx 4.02, and thi still does not work ???
Try installing the Radium MP3 Codec, you can get it from digital-digest, just a suggestion.
Unknown audio in AVI files
By courtneye in forum AudioReplies: 6Last Post: 29th Sep 2011, 11:24 -
missing mp3 audio codec in ulead when saving as avi
By gabz in forum Video ConversionReplies: 3Last Post: 24th Jul 2011, 17:23 -
unknown codec, mov container
By jlz901 in forum Video ConversionReplies: 4Last Post: 1st Apr 2009, 20:25 -
No Audio Output in AVI file where Codec is Installed
By yoshijam in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2008, 16:32 -
help w 'unknown' avi file
By rotuts in forum MacReplies: 7Last Post: 28th Feb 2008, 11:16
