hi all, i've been using TMPGenc + VDub to encode my movies to VCD with no probs to date until now.
I have a movie in Xvid MPEG 4. It plays fine in WMP 9. ( well it did after i installed the latest FFdshowdon;t know why)
but now when i try to encode it, the mpeg conversion comes out all distorted with horizontal lines and blocks and color runs.. i can see it in the preview window of TMPGenc
i am assuming its a codec problem.. but i dont know what to do.
as i mentioned, it plays ok in WMP but somehow doenst get along with TMPGenc
help pleasssee..![]()
help anybody ? i'm still stuck with a Xvids that only playable on my computer that i can't encode to mpeg...
hey Paul,
Does this mean that you're frameserving with VDub?
You could try frameserving with AVISynth. Otherwise, check to see if your xvid codec is up to date (...not really sure if this will help).Happy to be here. -
reencode the video to divx 5.11 using virtualdub first, then use tmpg to convert to vcd. That should fix the problem.
User's request to be banned.
/ Moderator Capmaster -
....And also diminish quality even further. Re-encoding isn't the best move. This is a codec issue, try resolving it first. Install the latest xvid codec, then try again with TMPGEnc.Originally Posted by gitreel
thanks for your help guys.
i might has mislead you with wong terms, so i'll explain it in step form.
basically what i am doing was doing is:
1) Copy out the wave using V dub.
2) Feeding the origianl avi with the new wav through TMPGenc to create the mpeg.
i thought it was a codec problem too. but it plays ok on the computer itself. only the resultant mpeg is distorted.
anyway, i will try out your suggestions and let you guys know if it worked.
thanks.
keep the advice coming
paul_yry:
I sometimes have the same problem as you - if I load the Xvid directly in TMPGEnc I get weird distrotion (maybe it has something to do with TMPGEnc and how it handles the Xvid codec) .... the easiest way to solve it is frameserve from VirtualDub. Feed TMPGEnc the VirtualDub .vdr file and your WAV file and it will work just fine.
VD Frameserving: http://www.doom9.org/index.html?/capture/Frameserving.htmlyour pal,
Stinky -
thanks a billion stinky. will give it a try as other methods don't seem to be working for me.
Need heavy duty LightScribe burner
By Robert W Cleary in forum MediaReplies: 5Last Post: 25th Apr 2012, 18:33 -
The Thing 2011 prequel **Heavy spoilers!!**
By retroborg in forum Off topicReplies: 6Last Post: 27th Mar 2012, 10:03 -
1080p movies are to heavy for my PC?
By fussgen in forum Newbie / General discussionsReplies: 17Last Post: 30th Aug 2009, 23:20 -
how to remove heavy noise in video?
By Driftking978 in forum Newbie / General discussionsReplies: 5Last Post: 26th May 2008, 05:24 -
boris FX plugins make premiere pro heavy performance
By yunakokimama in forum EditingReplies: 5Last Post: 3rd Mar 2008, 19:12
don;t know why)
