  1. Hi All
    I have ripped some MPG's from a VCD that does not work for me.
    When I try to play two of them I get an incorrect duration error message.
    If I use FFMEPGX I can view the MPG from there, but no sound, If I demux the MPG I can listen to the sound. If I then try and rejoin the sound and video I get incompatible file error messages.
    Anyhelp would be appreciated.
    Chris S
  2. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    you say the VCD's dont work?!? how so
    perhaps this is the reason they dont work as VCD.
