I tried capturing with Virtualdub but I can only get video - no sound.
So I used Windvr instead. I was able to capture video and sound, but the sound is terrible.
What can I do to get the audio in virtualdub? I know I did it before, but I spent hours trying to figure it out but I get the same result - no sound.
Results 1 to 10 of 10
Yes I can.
I can get audio using WinDVR, but it sounds terrible.
I have also used Virtualdub before successfully with audio. I just dont know what happened or what changed to make the audio not be recorded anymore. -
Since you have had success before, maybe you should check your connections. Perhaps the audio cable is not seated well or is in a bind.
If it works, don't fix it. -
What sound card are you using? If you're using the card that came with your computer, typically the capture is pretty bad.
fREBieware- you get what you pay for. -
I'm using XP Home, Celeron 1.1, 512 PC100 RAM.
The sound card I am using is not the onboard card. That broke down and am using a 4 channel ("C-Media" ?) sound card.
The thing is, I was successful before. I just cant remember what settings I used. I kept trying some more last night, but every time, I only capture the video. When the audio is there during the actual capture is in progress.
I'm connected to a VCR through a KWorld TV Tuner card. -
While playback on c-media cards is ok, the low-end cards (that's all that I'm familiar with) really suck at capturing.
As for your problem now, open the c-media audio control panel and check to make sure your recording source is set properly. Just because you can hear audio doesn't mean you can record it.
Then check the local or internet sales to find a better audio card.fREBieware- you get what you pay for. -
Thanks!
That was it.
One of the settings was checked, I think "microphone".
I took it off and it captured sound in Virtualdub again.
I do plan on getting a 5.1 card soon.
Once again, Thanks to everyone who helped. -
I think this may have answered my post, i've only got
onboard sound and i'm getting little or no sound.
You think a sound card would make all the difference.We're Bought and Sold
For English Gold. -
A lot of people have told me having on-board video and on-board sound actually sucks.
It actually takes away your memory and cpu power when you have these.
Very Poor Video/sound quality
By mikey56hernandez in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2011, 21:27 -
Poor Picture quality - need help!
By Martin747 in forum EditingReplies: 2Last Post: 26th Dec 2010, 13:00 -
Captured huffy AVI, convert to mpg poor.
By davexnet in forum Video ConversionReplies: 19Last Post: 15th Jul 2010, 22:01 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
Poor Quality
By Net_Bug in forum Capturing and VCRReplies: 3Last Post: 29th Mar 2008, 17:37
