I have:
Drive: NEC 1300A +- 4x burner.
Media: 4x -R Optodisk and Ritek media from rima.com.
Fuji dvd-rw from bestbuy.
I have flashed to various levels(official 1.0A and hacked firmware's 1.08v2 from herrie) with same result. Still cant use the Ritek's. I am using Nero 6.x version from like 2-3 months ago.
I thought i could run dvdrinfo pro on any dvd-rom drive and get media info. I tried getting the dvdrinfo media info from a new ibm reader that i have access to but the led read lite just keeps on flickering and doesn't go off. Only tried optodisk and ritek but it seems like it cant read them so i cant get media info from dvdinfopro. I can get media info from on the nec 1300a for the fuji and optodisk but not ritek. So I know it cant be nero as even dvdinfo pro cant read it. Tells me invalid disk.
I have not tested the disks on any other burner..
Bad media?? Ideas?
Thanks..
Results 1 to 10 of 10
Sounds like bad media. Many people have issues with Riteks and NEC. My NEC ND-2500A is not too fond of Ritek itself. Combine that with it being a poor reader, and its a nightmare.
If the other brands are working for you, I'd say stick with those. -
NEC's = burn like a flamethrower....read like a retarded 1st grader.
nuff said. -
OPTODISC, but not RITEK? I'd say firmware is faulty.
Nope. A lot of people have less than stellar performance with Riteks. You may have also received a "Bad batch".
Your firmware is ok.
Also as said before, the drive is a horrible reader, although its burning is stellar. -
It is funny of this that I just realize Ritek is not going to work on NEC burner. It happened to alot of people I know. I say stay away from Ritek if you got NEC burner. Try some other cheap but good brand
AnonymousGuest
I was nervous after reading this post, as I was burning my first Ritek dvd-r on my NEC 1300. Seems to work just fine.
FYI -Check out these 2 links in regards to this matter.
https://www.videohelp.com/forum/viewtopic.php?t=215531
https://www.videohelp.com/forum/viewtopic.php?t=215073
look toward the end of page 1 on this one. The dye type on mine is L19. I have no firmware upgrades as well.
Hope it helps
So far so good, I've been using Riteks on mine for a couple months now and they all play back in my 1300a.
Thanks for all the input.
I am going to get return the ritek's and get optodisks as they work fine.
BTW. The riteks i have are H4-5L19 (they are L19's i suppose) and have purple die. Fromt this thread, you all say these have proven to be the best ritek's. Maybe I got a bad batch. At least i have a known working brand for my 1300a.
I ended up using firmware 1.08 official with auto reset from herrie. Tried the other official and hack firmwares and this one seemed to work best. Leaving it alone
I just had a really funny idea, but no idea how to do it, help =)
By NukeyDoo in forum Newbie / General discussionsReplies: 3Last Post: 30th Aug 2009, 06:47 -
NEC ND-3500AG DVD RW DL burner doesn't recognize blank DVD's
By renegade431 in forum DVD & Blu-ray WritersReplies: 38Last Post: 8th Feb 2009, 07:16 -
Question about OCR that reads Chinese
By jimdagys in forum ComputerReplies: 1Last Post: 27th Nov 2008, 08:57 -
Dvd Burner only reads older dvds, won't read newer ones all the sudden??
By kpaxfaq in forum DVD & Blu-ray WritersReplies: 6Last Post: 28th Feb 2008, 15:11 -
DVD burner no longer "likes" Fuji DVD-R's?
By jlatenight in forum DVD RippingReplies: 6Last Post: 8th Oct 2007, 15:27
