Page 2 of 2
FirstFirst 1 2
Results 31 to 36 of 36
  1. Originally Posted by Stu Jordan
    How have you set up your AV2 settings? (Functions / Settings / Connections)
    My set-up is as follows:-
    Sky TV SCART to Panny HS2 AV2 SCART.
    Panny HS2 AV1 SCART to TV SCART.
    Sky is set to output RGB & Scart contol ON
    Panny AV2 set to RGB
    Only try Reset to Factory Defaults as a last resort as you will lose every thing on your HDD.
    Also try the Panasonic Customer Support Line below
    08705 357357 opening hours are 9.00 to 17.30 Monday to Friday (excluding Bank Holidays)
    Stu.
    Hi Stu,
    I have the AV2 connected up the same way as you. Sky to AV2, AV1 to TV, AV2 and Sky set to RGB. Recording from Sky+ too E100 works everytime.
    Do you think it is worth trying to do a dubbing with the Sky+ box turned off?
    Graham
    Apr 2004
    Kent, England
    Hi, Its worth a go. Try with a Ram disc first.
  3. Hi,
    Results of the latest test.
    I turned off all other equipment (Sky+, TV, Amp etc) so the E100 would not be getting any input from anywhere.
    I then inserted a DVD-RAM and formatted it to make sure I had a clean disk. I then started and FR mode dub with the same three episodes of The Handler.
    Result? 2 hours 4 minutes of a pink screen!
    It is almost as if the DVD drive has lost the ability to record from the HDD.
    Any ideas from here?
    Graham
    Apr 2004
    Kent, England
    Hi Graham. I am at a total loss now. It looks like you will have to talk to someone at Panasonic, or the dealer you bought it from. How old is the unit?, Sorry I cant be of any more assistance. Here are a couple of pointers:–
    Panasonic DVD Recorder Forum:- http://www.thewholewideweb.com/forum/default.asp
    Blank DVD Media Forum:- http://www.disqworld.net/
    Stu.
    Apr 2004
    Kent, England
    Stu
  6. Hi,
    The recorder is only a few weeks old. I did do another test which was High Speed to a DVD-RAM and that worked. I then tried an SP copy to DVD-RAM (XP source) and that failed. The problem does appear to be in the resampling of recorded data onto DVD.
    I will have a look at the forum you suggested.
    Graham
