Hi every1
After hearing so many good comments on DVD Rebuilder, I've decided to give it a try.
But I have absolutely NO knowledge about CCE, so I don't know how to configure Rebuilder to accept CCE encoding and do the thing right away, one-click!
I've tried searching for a simple guide to configure it, but couldn't find it. Can you help me with a quick guide on how to achieve this?
thanx!
..anyone?
any simple guide would help. I really couldn`t find a simple answer... -
I think that you should go to doom9.org. Go to one click solutions in the forum and I think that there is 42 pages of forum about this software not including the bug reports.
CCE 2.5 INSTALLATION
a) 1st follow the general INSTALLATION: directions
b) Install CCE
c) If using CCE 2.50 then get EclCCE from www.doom9.org at the download page. Download, unzip and install EclCCE. It will ask you
for the CCE program - use browse to locate it and finish the install.
Then run Rebuilder and under Options/Setup browse the path to
where EclCCE.exe was installed (not CCE)
d) Your screen should look like this
if using 2.6x or CCE basic then you do not have to install EclCCE
unless you are using a TRIAL version. Thus the settings directory
as shown in the above picture should instead point to where CCE.exe
is)
Other settings as shown in the next pic:
1. Download and install AVISYNTH. It is available at www.doom9.org -- at that
site click on "Download" on the left navigation bar. AVISYNTH is available under
"Support Utils" -- at the time of this writing the most current version was v2.54
which has been tested and is completely compatible with DVD-RB.
2. From the same link, download and install DVD Decrypter. Follow the
instructions. At the time of this writing the current version was 3.2.1.0 --
and it has been tested and works great with DVD-RB.
3. Next, you must have a copy of MPEG2DEC3DG.DLL installed on your computer.
At the Doom9 site, download DVD2AVI dg. It (at this writing) is contained in a
ZIP file DECODEFIX100.ZIP. Open that zip and within you will find a file called
MPEG2DEC3DG.DLL. Copy that file into a directory called "PlugIns" under the
AVISYNTH directory (created in step 1). Putting it there could save you lots
of possible headaches later!
4. There -- that's all the support software needed -- but you need one more thing.
You have to have (your choice) an encoder. My top recommendation is Cinemacraft
Encoder Basic for the best quality output imaginable. This software is available
at a cost of $59 from:
http://www.cinemacraft.com/eng/ccebasic.html
Should audio track be smaller after DVD Rebuilder/CCE?
By hiimbored in forum DVD RippingReplies: 3Last Post: 22nd Jan 2009, 09:10 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 13:25 -
question about CCE Customized Settings in DVD Rebuilder
By jimdagys in forum DVD RippingReplies: 1Last Post: 30th Oct 2007, 04:20 -
DVD Rebuilder Pro & CCE in Multipass VBR mode
By devnulllore in forum Newbie / General discussionsReplies: 12Last Post: 30th Jul 2007, 09:04 -
Best Advanced CCE Settings in DVD Rebuilder
By devnulllore in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2007, 11:56
