I am looking for two types of conversion software. I am looking for something that will convert .VOB to Mpeg2 (or AVI). Second, I am looking for something that will convert Mpeg2 to AVI. The first one I have done before with a trial version of Trex (by Pinnacle), but I now cannot find that software. Any idea where i can find it?
Results 1 to 24 of 24
DVD2AVI can produce an AVS file that can then be opened in VirtualDub, which you can use to produce an AVI file with compression of your choice.
VirtualDubMod can be used to directly open a VOB file and produce an AVI. It can also produce an AVI from an MPEG2 file.
Another program built around VirtualDub that will do what you want is VirtualDub-MPEG2. I have not used this version too much, so I cannot make a comparison between the two.
Both are available in the TOOLS section. -
it keeps saying "No Video Frames found in mpeg". What am I doing wrong?
kenman wrote:
I think the problem is between your desk and your chair
At work, we refer to this as pebcak. Problem exists between chair and keyboard.
Aaaaaanyway... back to the problem at hand...
If vdub-mpeg2 is complaining, then there is something wrong with your source files in all likelihood. How did you get the VOB's on to your machine? -
right now I am trying to convert .mpeg2 to .avi...I am not doing the .vob to .mpg2 at the moment....I have some mpeg2s that I am trying to convert to avi because I can't get DVD Moviefactory to work with these files.....
When you open the MPEG-2 file in VirtualDub MPEG-2, go to File > File Information. Does it clearly show that there is a video stream ?
Are you trying to open a .MPG, .MPEG, .M2V or a .MP2 file ?If in doubt, Google it. -
Step me through it...
You open virtualdub MPEG-2. You go to open, select the filename and then the error comes up ?If in doubt, Google it. -
it never gets that far...it is like it doesn't read it at all....(I know...I am a newbie.)
I'm sorry...i missed your other post....I open up VirtualDub...then I go to File and then 'Open Video File' and I select the file. Then it comes up with the error 'No Video Frames Found in Mpeg File". i think i am missing something from the Virtual Dub
I hope you aren't using the standard VirtualDub ? We mentioned many times that you need a hybrid version called VirtualDub MPEG-2. Click the link.
the one I got was Virtual Dub MPEG-2, but it must have been a bad one. I downloaded another one, and that one works. However, I have to experiment with it. The footage is very interlaced (although that is the way it was before) there is a prominant line in the middle of the screen.
the file extension for the 'end result' file? It is either .mpg or .m2v....I do have it set to system (video + audio.) I get picture, but no sound.
Originally Posted by burdell1It is pretty hard to work out;Originally Posted by burdell1
1. What you are starting with
2. What you are trying to do with it
3. What you want it to end up as
Answer these three questions in as much detail as possible and we might be able to work something out.If in doubt, Google it. -
I would open Tmpgenc and I would drag over the mpeg2 file that I want to de-interlace. Whenever I drag it over, it only show up in the 'Video Source' spot, the 'Audio Source' remains empty. however, I realize now that I only had the System (video) checked. So, I switched it to System (video + audio) and it acts like it is working, but the progress bar does not move at all.
I use SuperDVD Ripper to produce mpeg-1 and mpeg-2 (VCD & SVCD, respectively). You Control-click on each VOB (in the appropriate VOB>SVCD "Wizard" dialog) in reverse order (5, then 4 then 3, etc.); this loads them in the proper order, believe it or not. Follow the rest of the wizard and then be patient. It works great.Originally Posted by burdell1
Quality is excellent. Only downside is that you don't get a choice of bitrates (SVCD, no "XSVCD", in other words). It will incorporate the subtitle or an alternate language (assuming they are available in the VOB).
Software to find duplicate pictures
By hamilton accie in forum ComputerReplies: 1Last Post: 29th Apr 2012, 14:49 -
Can't Find a Conversion from MP4 that SONY Digital Frame DPF-D830 Will Play
By pmconway in forum Newbie / General discussionsReplies: 4Last Post: 29th Apr 2012, 03:11 -
VERY specific conversion specs - Can't find a converter that cuts it.
By VWsplitUK in forum MacReplies: 1Last Post: 26th May 2011, 11:55 -
How to find out which software created the video CD I made years ago?
By Tjjjc2 in forum Newbie / General discussionsReplies: 4Last Post: 20th Dec 2009, 03:28 -
find software to resync. .avi and .srt ?
By neutralidea in forum EditingReplies: 3Last Post: 11th Feb 2009, 22:10
