I've been capturing some TV shows using the passthrough in my Sony Digital8 camcorder for a while now, and I've started noticing that when scenes within the program change from a sequence of bright light to a darker sequence, the camcorder is almost 'refocusing' (for want of a much better, technical word) the image, and the brightness from the previous scene fades in to the new light setting of the next sequence - almost in the same way as if you go from inside to outside while recording on a camcorder - the little bit of time it takes for the camcorder to adjust to the new setting.
I don't see why this needs to do it during passthrough though, and was just wondering if it's just a matter of my camcorder's configuration that can be changed? It's only really notable when there is a clear juxtaposition of a particularly bright, white scene (indeed, it doesn't seem to like a pure white image at all!) to something else... but there's quite a few programmes I want to capture currently that do this, so hopefully there's a way to fix it.
Just going out and buying a proper DVD Recorder is looking all the more tempting.
Results 1 to 1 of 1
Passthrough Video and convert Audio
By Teoulis-69 in forum Video Streaming DownloadingReplies: 2Last Post: 21st Jul 2019, 12:50 -
HDTV for analog passthrough video enhancement?
By bizzybody in forum Capturing and VCRReplies: 2Last Post: 25th Feb 2012, 03:22 -
VIDEO_TS to AVI xVid with AC3 5.1 passthrough - problems
By couldtryharder in forum ffmpegX general discussionReplies: 11Last Post: 29th Nov 2011, 10:08 -
A converter with a passthrough option for video track.
By Soner in forum MacReplies: 8Last Post: 20th Apr 2010, 15:27 -
Problem with video passthrough codec
By Modemserf in forum ffmpegX general discussionReplies: 0Last Post: 19th Jan 2010, 23:01
