I am using Pinnacle Impression DVD Pro for DVD authoring and Ifoedit 0.96 to try and fix it.
After looking at the IFOs of a DVD project I created, I see there are both post commands and cell commands.
I believe the cell commands are this problem.
When pressing NEXT button my DVD remote if the title (like a 1 chapter music video extra for example) it goes to the next title (not back to the menu like when you just let it play out).
Is it okay to delete the cell command? Will this fix my problem, or do you have to modify the cell command to mimick the same action of the post command (which directs it back to the menu)
Any help would be greatly appreciated.
Please e-mail the response to trevorzimmer@hotmail.com
Thanks,
halogen
