Hi,
When I capture a screen shot from PowerDVD, the resolution is very low and there is no option to set a high-res capture. Is there any player or program to take a screen shot in high-res about 300 dpi? I want to take a screen shot from the movies to create and print my own cover art.
Thanks.
Max DVD resolution is 720x576 (480 for NTSC). There's not much PowerDVD or any other tool can do about it.
But it's not so much the resolution. It's a lossy-compressed motion picture you're trying to get a still image from. You can't expect very good quality from that.
Try to get a still from an I picture. That should give you slightly better image. I'm not 100% certain but I think when you reverse by frame it moves to an I picture. -
This is not going to give you a better print. You can over sample all you like but the picture quality is not going to improve.
Mark
Looking For High Res Animation Advice
By David Bethel in forum Newbie / General discussionsReplies: 119Last Post: 8th Mar 2010, 11:09 -
Converting High res JPG File into HD Slide show/HD Movie
By dominic01 in forum Video ConversionReplies: 4Last Post: 13th Oct 2009, 01:58 -
Unable to capture screen shot for background
By Cole in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 17th Jan 2008, 14:53 -
Advice on High Res Video Capture Hardware
By Gregus in forum Capturing and VCRReplies: 3Last Post: 15th Jun 2007, 14:54 -
High Res Presentation video (Frapsed)
By Flawe in forum Video ConversionReplies: 1Last Post: 28th May 2007, 06:01
