  1. How do you backup a DVD that is a back up DVD via DVDX Copy Express? DVD shrink does not work. It always freezes after reading the dvd.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Let me see if I understand this correctly, you are trying to back up a backup, yes ?
    If in doubt, Google it.
    Apr 2003
    Maryland
    I just drag the files directly to my HD and burn. Run ANy DVD in the background and you can directly drag a DVD folder set to the HD as well. If its a DVD 5 you can burn directly. If not, you run it through shrink. I know it soounds incorrect and even I don;t so it that way, you really can as long as you are running anyDVD in the background to defeat all protection.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
    Dec 2002
    My Swamp
    Ive seen various threads before about copying a back up made with DVDX Copy and it seems DVDX does something that makes copying them difficult.
    Have a look at THIS thread.
