I use DVD Shrink to rip most of the time and use Nero for burning. I just noticed a problem that has happened on every backup I've made using DVD Shrink. The widescreen image is distorted on my HDTV. The image is squeezed down and makes everything look short and fat. If I play the dvd on my computer or on a 4:3 TV, the image is fine. Backups I have made using other software do not have this problem. Has anyone else experienced this using DVD Shrink? I have played around with all the settings on my dvd player and TV to try and get the picture looking the way it should. Nothing works. The original discs play fine. I'm assuming it's something with the encoder in DVD Shrink.
