hi folks, need suggestion on authoring software that supports menus and multiple audio ac-3 selection and motion menu support.
so far i have tried tmpgenc mpeg dvd author but only supports one ac-3 audio channel, but has the features i like.
ulead dvd workshop i think supports dual channel but i cannot fit as many clips on one dvd as i can with dvd author.
ulead movie factory is just terrible.
thanks for any suggestions.
tmpgenc dvd author can import dual channels, 5.1, ac3. or do you mean several selectable audio tracks? then try the dvd-lab pro beta. if you want a free tool try ifoedit or dvdauthorgui, very limited tools but they support audio tracks.
Best Authoring Tool for BD
By michcio in forum Authoring (Blu-ray)Replies: 2Last Post: 24th Jan 2012, 03:40 -
authoring tool for HD video -> DVD
By feh in forum Authoring (DVD)Replies: 2Last Post: 13th Jan 2009, 14:03 -
Which DVD Authoring Tool ?
By Leo48 in forum Authoring (DVD)Replies: 5Last Post: 1st May 2008, 15:37 -
What is a good authoring tool?
By breeze9 in forum Authoring (DVD)Replies: 1Last Post: 26th Jan 2008, 00:17 -
Which DVD Authoring tool to use?
By jodajen2 in forum Authoring (DVD)Replies: 6Last Post: 14th Nov 2007, 09:21
