  1. Hey
    I want to put some WMV files (.avi)
    [FourCC : WMV3 Windows Media Video 9]
    On some DVD cd's, and since the "Centrum Gemini 332" dvd player dont handle WMV as I can see it (or am i wrong? no review mensions WMV at all) I need to covert them to either Divx or Xvid .. Does anyone have the slightest idea on how to convert these files? I would really appricate some help ,Searching guid's didnt go to well
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    The easiest way would be to use Dr. Divx, which is trialware. If you only want to use freeware tools, things will get fairly complicated.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    The last version of virtualdub with asf support (1.3c) can do it also.
    If in doubt, Google it.
