! Hello everybody ¡ I have a capture card PINNACLE DC10 PLUS, It used a MJPEG codec, if I capture various 2GB files because it is limited by W98 (my HD is FAT32 and it should be a 4 GB file), How can I paste multiple 2GB files in just one long file? Do I need a special program?, I am using Studio DC10 1.06.
Any help will be appreciate.
I thought I have read from Pinnacle web site that the DC10plus has get away with the 2GB limitation.
Studio DC Plus save 2 GB files, if you are trying to capture 6 GB file the program save three 2GB files. What I am looking is a program that paste all those three file in one long file.
Bear in mind that, as well as specific limitations on the sizes of .AVI files, *no* file in W98 can be larger than 4Gb if it resides on a FAT16 or FAT32 partition. Personaly I'm just learning to live with the fact that huge captures are segmented...
avisynth's SegmentedAVISource("base-filename"[,...]) function will splice your captures together prior to encoding. alternatively, append the segments in virtualdub & frameserve
http://www.theharangue.com/ripping_preferred.htm
there's a section regarding segmented avi -
Should check more into your Pinacle card because my Hauppuage PVR MPEG2 Encoder card will encode any length I want and it just breaks them down into 2GB files, but at 480x480 MPEG2 SVCD I can get a entire 2 hour movie at just under 2GB.
Bitrate Limit for BD9?
By wulf109 in forum Blu-ray RippingReplies: 4Last Post: 6th Jan 2012, 08:56 -
Sony Video Capture 6 (Vegas MS) hard drive max size limit?
By distendo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Jun 2008, 10:02 -
AC-3 bitrate limit on Apple TV?
By InsanelyOne in forum MacReplies: 0Last Post: 8th May 2008, 11:18 -
****** You have reached your license limit.
By red-bull in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 4th Mar 2008, 05:23 -
By microbar in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 10th Sep 2007, 19:28
