Error in MPEG stream at offset (bits) 13: Supposed marker bit not found
help this message comes up when im trying to mux in bbmpeg here's my log
Video: none
Audio: none
Output MPEG information
Video: none
Audio: none
Multiplexing: video and one audio stream
program stream type: VCD
video file: c:\windows\desktop\video.m1v
audio 1 file: c:\windows\desktop\encodedaudio.mp2
program file: temp.mpg
Multiplexing video and audio:
Scanning video stream for a sequence header ...
Scanning video stream for pictures ...
Found 159052 picture headers.
Video stream information
Stream length : 722537733
Total time (seconds) : 5307
Sequence start : 5302
Sequence end : 1
No. Pictures : 159052
No. Groups : 5302
No. I Frames : 5302 avg. size 14055 bytes
No. P Frames : 47716 avg. size 6467 bytes
No. B Frames : 106034 avg. size 3201 bytes
No. D Frames : 0 avg. size 0 bytes
Horizontal size : 352
Vertical size : 240
Aspect ratio : 1.0950
Picture rate : 29.970 frames/sec
Bit rate : variable
Computed avg rate : 136250 bytes/sec (1090000 bits/sec)
Computed max rate : 282400 bytes/sec (2259200 bits/sec)
Vbv buffer size : 40960 bytes
CSPF : 0
Scanning audio stream for access units information
then the error comes up
how can i fix this?
if you need more info just ask
