while encoding a video, i used HuffyUV, then i placed it in tmpgenc, were i accidentally chose non-interlace and 352x240. on an earlier post, someone said to never use 352x240 for DVDs since only progressive is supported. under normal conditions, i would rerender with the effects, then convert to 352x280i, but i deleted the files cause it was taking alot of space on my HDD (more or less 8 gigs). so should I reencode the 352x240p file thats dvd compliant to 352x280i? my main concern is the quality - i hate noisy and grainy videos.
The threshold for interlaced video is 280 lines vertical, and this vertical resolution is only supported by PAL (352X288 interlaced VCD, which isn't recommended anyway). NTSC would need a vertical resolution of 480 to be interlaced. Since 352X240p is a valid resolution for NTSC DVD while 352X280i isn't, so keep it at 240p. Anyway, you have already interpolated the data by losing one of the fields and you can never get it back. It won't have any effect on grainyness/noise and actually rencoding at a higher resolution at the same bitrate may only add noise to your video. 240p resolution just doesn't look as sharp as a higher resolution. Keep your file the way it is if you like how it looks. Rencoding will not improve quality.
but i thought that for NTSC DVDOriginally Posted by xtreemkareem
"352 x 480 pixels MPEG2 (Called Half-D1, same as the CVD Standard)"
https://www.videohelp.com/dvd
thats what its saying. as for the original topic, i'm guessing i will stick with progressive. -
Yes, for NTSC DVD MPEG-2, 720X480, 704X480 and 352X480 are all valid resolutions. However, the DVD standard also supports 352X240 MPEG-1 at 1876 kbps, 48khz audio, often called a VCD-DVD. It should be liusted in the guides. Or you could just make a plain old VCD MPEG-1!
Question about HD to SD and interlace>progressive>interlace
By ayim in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 12:21 -
interlace - progressive problem
By jin007 in forum Newbie / General discussionsReplies: 1Last Post: 18th Aug 2008, 10:55 -
Interlace or Progressive??
By Browncoat in forum Newbie / General discussionsReplies: 9Last Post: 31st Jan 2008, 15:14 -
Interlace/progressive detector
By demonwarrior in forum Newbie / General discussionsReplies: 9Last Post: 6th Dec 2007, 00:35 -
29.97 interlace to 23.976 progressive
By Alex DeLarge in forum Video ConversionReplies: 5Last Post: 8th Aug 2007, 18:09
