Hi all,
I'm new to playing with video, so I'm hoping someone more experienced can help me out with this. I'm trying to pull video from a VCD, and to convert it to DivX. Here are my symptoms:
1) I can watch the whole VCD (53 minutes) on my PC with Windows Media Player.
2) When I try to load the .dat file from the VCD into VirtualDubMod, it begins to parse as normal, but about halfway through it seems to skip to the end, and VirtualDub then only loads the first 29 minutes of the video.
3) I created an mpeg file with ISOBuster, and can watch it in its entirety with PowerDVD.
4) When I try to load the mpeg in VirtualDubMod, the file same thing happens as when I try to load the .dat file directly.
I have d/led AVISynth, and tried the MPEGDecoder script. When I try to load the .avs file in VirtualDub, however, I get a popup saying "Creating a d2v file," which then stalls out. I've also tried using the DirectShowSource script, but that won't even load in VD: I get an error saying "No combination of filters could be found to render the stream."
I just tried re-extracting the mpg with VCDGear (which apparently fixed 5 errors), and could play the entire file with PowerDVD. Trying to load it in VD with the AviSynth scripts, though, I get the same results.
If anyone could offer some suggestions, I'd appreciate it. Thanks,
Christopher
Thanks again for the help. I wasn't sure how to do what you explained, so I started playing with Tmpgenc and figured out a circuitous way of getting what I needed: when I loaded the .dat file in Tmpgenc and tried outputting an mpeg, I kept getting an audio error. So, I created separate video and audio tracks, then combined them in VD. This seems to have worked like a charm.
Cheers,
Christopher
mpg to DV-AVI converters
By nuttyDeedee in forum Video ConversionReplies: 7Last Post: 31st May 2009, 18:13 -
[FFMPEG -> VCD-MPG] How to push CBR?
By Gew in forum Newbie / General discussionsReplies: 4Last Post: 13th Apr 2009, 10:05 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
avi to mpg
By zoranb in forum Video ConversionReplies: 7Last Post: 12th Sep 2007, 16:09 -
I used Super to convert AVI to mpg VCD...........................
By videonewbie69 in forum Video ConversionReplies: 2Last Post: 23rd Jul 2007, 12:34
