I want to capture some screen shots from a vcd that i made at home and put them on my computers at work as background.
how do I get these from the vcd, and what is the file type to save to? I used my firewire and a mgi product to capture the footage (dv) and TMPenc to get the vcd done.
thanks
mikegee
I know you can do it in power dvd. Also you could open the .mpg in virtual dub and use the cntr+1 screengrab to get the frame. Keep in mind you'll have to change the aspect of your picture since a VCD is 352x240 while 320x240 is the aspect it needs to be in so the people don't look stretched.
make new file form selection
By pribl in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2011, 05:08 -
Loading IE in maximum form
By jyeh74 in forum ComputerReplies: 6Last Post: 7th Dec 2010, 05:52 -
What is your primary form of communication?
By yoda313 in forum PollsReplies: 16Last Post: 1st May 2009, 18:02 -
Getting files from camera into editable form
By Nilfennasion in forum MacReplies: 3Last Post: 22nd Oct 2008, 07:01 -
hiding windows/items form the taskbar
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 28th Aug 2007, 20:26
