I have VCD's
I have properly sent them through VCDGEAR - fix
I reencoded them even, using TMPGenc, with MPEG1 settings, and with, on one try, a 1:1 VGA ratio, full Screen, and another try, a 4:3 NTSC ratio. When the resulting files are run through SVCD2DVD, they are different window sizes on a computer, but they are the same oversized video on a hardware DVD player for a Television. What settings should I use, specifically, when I reecnode a VCD (to get rid of any errors), under TMPGenc? Should I use VBR or CBR (i have been keeping CBR, the default setting). Anything else?
I am out of ideas.
What can I do to make sure that my resulting DVD's fit on a TV screen? I have tried it on two TV's, with the same results. The TV"s are average, no special plasmas or flat screens here, but they are somewhat new (a few years old Panasonic and Daewoo)
I appreciate any and all help. Thanks!
By how much are they too big. If it is only a few % on each edge, then that is caused by TV overscan and is perfectly normal.
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36 -
395MB folder to big to fit on 700MB CD in ImgBurn
By happydog500 in forum AudioReplies: 30Last Post: 30th Jul 2008, 13:58 -
video doesn't fit my TV screen
By hzgg2 in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2008, 07:56 -
Resizing to Fit TV Screen
By bolson1 in forum EditingReplies: 2Last Post: 12th Feb 2008, 22:49 -
DVD fit on screen
By NHLroyrocks in forum Authoring (DVD)Replies: 6Last Post: 21st Jun 2007, 16:54
