What is the difference between DVD-Rom (UDF/ISO) and DVD-Video when burning DVDs with Nero? Which one should be used and why?
Depends on what you're burning. If you're burning a movie you want to play in your dvd burner, use DVD-video. All it does is add a Video_ts and Audio_ts folder to the disk so the player recognizes it as a movie.
If you're burning random files, go with ISO or UDF.
UDF = Compatible with Macs and PC's.
ISO = Compatible with older computers and OS's (like windows 95) but no mac-Yar, matey!- -
Burning movies to be played in stand alone DVD players and computer DVD drives. Can one format be used for both computer and players?
For movies, just use DVD-Video. It'll work on both standalone players and computer dvd drives. Just make sure you drag the movie files in to the video_ts folder!
-Yar, matey!- -
Thank you for the information. I have been burning using DVD-Rom (UDF/ISO)? What would one use DVD-Rom (UDF/ISO) for?
What would one use DVD-Rom (UDF/ISO) for?-Yar, matey!-
It's funny how we have no life and we just sit here waiting for a response
Well, no. I get email notifications on my phoneBut still....
All these questions/responses in less than 45 mins-Yar, matey!-
free software for burning data dvd in ISO (not UDF) file format
By Toastie in forum MediaReplies: 3Last Post: 29th Oct 2010, 17:18 -
File structure of UDF-ISO image files
By Waly in forum ProgrammingReplies: 5Last Post: 21st Oct 2010, 09:44 -
How can I salvage ISO with invalid UDF File Syetem?
By V Bot in forum Video ConversionReplies: 1Last Post: 10th Jan 2010, 20:37 -
Created DVD(UDF) in Nero, works on some computers, not all
By ir0n_ma1den in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2009, 21:51 -
UDF or ISO when burning a multi DivX DVD-R
By perceptionist in forum DVD RippingReplies: 3Last Post: 4th Jun 2007, 13:10
