  1. Just need some rule of thumb formulas here,
    Ie Capture AVI from DV camera to HD 1 min = ? file size on HD
    Then AVI to MPEG 2 1 min of Avi to PAL best qual Mpeg2=?file size
    Cheers
  2. Member daamon's Avatar
    Melbourne, Oz
    Hi Divxwannabe,
    1 hour of DV AVI is approx. 13.5Gb
    When converting to MPEG2, the filesize is purely a function of the bitrate and the running time (in seconds) of the footage.
    There is no bitrate for "best quality" as there are too many other factors to take into account. However, a rough guide would be 7,500 - 9,000kbps.
    Use the DVDRHelp Bitrate Calculator in "Advanced Mode" to see the effect "Video Length" and "Bitrate" has on file size. Note that you can adjust the bitrate for both video and audio.
    Hope that helps...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. Thanks Daamon! Great site this one!
  4. Member daamon's Avatar
    Melbourne, Oz
    Hi Divxwannabe,
    No problem. Certainly is!!!
    Carpe diem.
