    I am converting a dvd from pal to ntsc. I converted the video from 25 fps to 23.976 fps with an avisyth script and encoded with cce. I then used dvdlab to do 3:2 pulldown to convert the video to 29.97 fps. I have a question about the audio. In besweet do I go right from the 25 fps to 29.97 in framerate adjustment to correct the audio?
    Apr 2002
    Oskeeweewee Ontario
    Nope, 25fps to 23.976fps.
    Are you using .AC3 machine as a front end? Watch for crackling noise, depending on what version u use...
  3. i,m also doing the same thing, only from svcd pal to dvd ntsc.
    but my problem is that i cant get besweet going? whenever i hit mp2pal to mp2 i does not start transcoding. however if i left click the tab and keep the cursor on the tab, it will read out TRANSCODING and the timer will go on, but it will never stop, it will just keep going, and to make it worse, when i look in my output folder, there is nothing!!!
    i would greatly apreciate help with this one.
    thanks
