Can anyone tell me a great program for making an exact copy of my hard drive onto another hard drive?
I am using WinXP Home
I bought a larger drive and want to put my boot up drive info on this drive
Suggests?
NORTON GHOST
Drive Image v7. but better yet use the software that came w_your new hard drive (MaxBlaster, etc.) and transfer the old drive (content) to the new.
Ok so maybe I forgot to ask...
Is there any relally good ones that are freeware or sharware? -
Why not use the software that came with your drive(unless there was none)? I've had good results with both the Maxtor and Western Digital bundled tools.
If it is a Western Digital HD you can use the Software that came with the drive...or if you bought is as an OEM you could download it from the WD site.
No, I'm from Iowa. I only work in outer space.
how do i copy DVDRAM disks to a pc hard drive (retaining exact quality)
By mnbvc in forum DVD RippingReplies: 19Last Post: 23rd Sep 2015, 15:18 -
Exact Copy of DVD made in Poland from Hard Drive of LG recorder
By dubronidog in forum MacReplies: 5Last Post: 18th Nov 2010, 10:14 -
How to copy "DICOM" CDs to hard drive then run from hard drive?
By JohnnyBob in forum Newbie / General discussionsReplies: 1Last Post: 25th Apr 2010, 18:18 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 18:29 -
how do i copy DVD RAM discs to pc hard drive (retaining exact file quality)
By mnbvc in forum Authoring (DVD)Replies: 3Last Post: 19th Apr 2008, 18:32
