I have been making backups of my movies and have had success with them. However, a friend of mine told me there is a program that he has that will put the entire disc with menus and special features on to a DVD5 with no quality loss. I don't know how this is possible. I could understand if it was a Single Sided disc but most that I make backups of are Double Layer. Is anyone familiar with this software? He wouldn't tell me the name of it but with any compression, there is going to be some quality loss.
Results 1 to 12 of 12
And you believe this?!
This can be true in particular cases, where the DL-disks have only less than 4.38 GB.
Give your friend a link to this site! -
He was telling me all of his backups even dual layer. I wanted to tell him he was full of crap.
Well, it would be pretty daft to make a DL-disc from less than 4.38bg. Why do it when you can put that amount of data to a SL-disc....
"This is true in all walks of life: Man takes care of the quantity, woman the quality." -
Tell him!
Say him that you have a friend which can put an elephant in his VW Golf!
It is exact the same thing! Could it be possible? Yes if the elephant is just born, maybe... -
If in doubt, Google it.
Is it possible to take 8.4gigs of data & make it 4.7 gigs of data with no quality change? Nope.
Please do so!Originally Posted by paj27
"Art is making something out of nothing and selling it." - Frank Zappa -
NO quality loss indeed. Definitely not possible. Minimum quality loss, yeah, that sounds about right. Tell him that I can squeeze the entire Lord of the Rings and/or Matrix trilogy into a single disk with no quality loss using freeware readily available
. Would he believe that?
No, it wasn't April 1st when he told me. However, if it was possible to compress to 1 disc with no quality loss, there would be no reason to buy Dual Layer Burners. Anyway, I have been using Intervideo DVD Copy and it is doing good so far with the entire disc. My point to my friend was that there is always some quality loss with compression.
Double layer DVD-can I burn 2hr at Highest quality?
By jbitakis in forum Authoring (DVD)Replies: 2Last Post: 21st Apr 2011, 12:59 -
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 17:13 -
Burning Double Layer DVD with no Layer Break.
By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 14:26 -
DVD+R9 Double Layer first burn: problems with layer switch
By Edmund Blackadder in forum DVD RippingReplies: 400Last Post: 4th Oct 2009, 12:27 -
How to shrink DVD9 to DVD5 with no Quality loss?
By CERO in forum Newbie / General discussionsReplies: 7Last Post: 4th May 2008, 07:18
