is it possible to buy Philips DVP642 DivX, XviD, MPEG4 DVD in the UK.
Results 151 to 180 of 209
Originally Posted by MrPib
Originally Posted by fskof
Okay, why on earth does a 720x416 pixel AVI display full-screen when played with this player?
If anyone out there has figured out all the mysteries of how this player scales/distorts AVI resolutions, please reply!
These are the rules I have determined so far:
1. For an AVI that has a *width* of 720 pixels or 704 pixels, the AVI will be stretched vertically to create a 4:3 output....so even if your AVI is 704x100, it will play full-screen.
2. For an AVI that has a *height* of 240 pixels, the AVI will be stretched or shrunk horizontally so that 352 pixels corresponds to full-screen width. In other words, a 352x240 pixel AVI will play back full-screen, while a 320x240 AVI will be squished horizontally (to about 91% full-screen width), so that there are black borders on the left and right.
3. For all other AVI's, the proper 1:1 VGA aspect of the AVI is respected. The AVI is scaled proportionately to fit on the screen. It seems to choose a scaling such that 704 pixels corresponds to full-screen width. In other words, a 640 width AVI will be scalled proportionately, but will not fill the entire width of the screen. Also, I swear that some 720 width avi's *are* scaled proportionately -- I have no idea why the *magic* height of 416 pixels leads to a full-screen distortion.
Any comments welcomed...Also if anyone knows where to download a simple test disc containing AVI's of many different resolutions, which are just a pattern that is black with a white circle, that would be a great way to test AVI scaling on divx players!
Everyone knows that an AVI should have a 1:1 VGA aspect ratio (it is what it is), so I don't understand why they didn't design the divx player to play them all appropriately. -
I don't have a receiver that does DTS, so I can't test it myself, but since I'm mostly likely getting a surround setup at some point, it would suck to not have DTS on my DVD player. -
Well, this player does very poorly at playing back AVI's with the appropriate aspect ratio.
It appears that for AVI's with width greater than 704, this unit:
1. resizes vertically to full-screen resolution (i.e., 480 lines)
2. resizes proportionately so that the width is 704 pixels.
The result is that a 720 width AVI will have very thin letterboxing on top and bottom...and it's aspect will be off....
So, a 720x416 pixel AVI will be stretched too much vertically on a 4:3 TV and will be slightly squished vertically on a 16:9 TV....take your pick - fat people or skinny people...no way to make the aspect right. -
I admit I don't have one of these but I thought full screen resolution for the MPEG-4 codecs (like DivX and Xvid) was 640x480
So what happens if you play back a full screen DivX AVI at 640x480?
There should be some sort of manual resizing for the player. I have to adjust each file when I play an .avi with my lite-on LVD-2002 using the zoom function, it works differently than when playing a DVD. You can bassically adjust the horizontal and vertical res seperately when playing an .avi
Look, let me explain something. I'm not Mr. Lebowski; you're Mr. Lebowski. I'm the Dude. So that's what you call me. That, or Duder. His Dudeness. Or El Duderino, if, you know, you're not into the whole brevity thing-- -
Originally Posted by LisaB
I found the solution concerning the grey line, in the played movie, go to video setup, switch to Progressive and return to normal immediately, the grey line is disappeared
I well look forward to seeing a new firmware to correct the manually zoom...
Bye
Dynoqc -
FulciLives, 640x480 plays back fine and undistorted on this unit. That's a good choice if encoding a full-screen movie, but I think it's unreasonable that we should have to letterbox our widescreen AVI's just to get them to play back properly on the standalone.
Interesting solution for the grey line problem, but it doesn't help those with HDTV's who keep their unit in progressive all the time. -
That sounds to me what you are saying.
In that case I guess the work-around would be to encode widescreen with the black so you end up with 640x480 total image size.
Hey can any1 tell me what this firmware does besides mess up some of the controls. Does it:
A.Improve playback compatability for Divx/Xvid files
B.Increase loading speed of discs
C.Fly around the room spitting flaming DVD's
D.All of the above
But I just want to know before I upgrade my player -
I have not of HDTV (I have only a old panasonic Gaoo TV of 1992) , it is necessary to put back the normal tv mode afterward, try this: choose progressive and cancel...
Dynoqc -
The player does stream dts to your receiver if you connect via digital outputs and your receiver can decode it (Have not tested it with analog audio). The message that you have to manually get rid of are annoying
The biggest problem I have is that the player heats up a lot when using it.
Is that normal ? -
si, i just bought one and played 2 xvid no problem, tried the 3rd and got "unsupported codec" the codec used was xvid rc1.. other then that it seems to be working good, but why would i get unsupported codec?
I'm tempted to re-buy a DVP-642 at CompUSA just to try it. As I said, it's a nice player otherwise. (And I have a store credit burning a hole in my pocket from my return of the 1st one -- I took the credit to avoid the 15% restocking fee).
Thanks for the info! -
jacobb, you got an "unsupported codec" message because your video file contained b-frames. This player does not support b-frames, which are a newly added feature in Divx 5.1.1, and can also be used with the final XVID. (you mentioned the file you tried to play was a release candidate of XVID...by the way, the final is out)
B-frames give a little boost to encoding efficiency/quality, and since they are now supported in the latest Divx and Xvid codecs, you can expect to see more and more files that this player won't be able to play. Remember that using B-frames is optional, but many encoders will choose to use them since they'll give a quality boost for a given file size. You just have to remember not to use them when you encode your own Divx or Xvid, if you want them to play the video in this player.
You should probably not buy this player if you want to play files downloaded through filesharing, etc. In a few months, you can expect that this player will not play *any* newly encoded divx/xvid. B-frames are rapidly becoming the standard, and this player will soon be obsolete. It should play most of your current collection, however, if that is good enough.
This player does a great job playing those video files it is compatible with, but it doesn't do subtitles, b-frames, OGM container, PCM audio, or Divx audio, and it screws up the aspect ratio of almost every divx/xvid that doesn't have a width of 640 pixels. One kind of cool thing this player *does* do is that it will play AVI with multiple audio streams (you can switch between the audio streams using the "audio" button on the remote control!). I don't know if anyone else had noticed this feature, or whether other divx standalones did this, too.... -
lifeisfun,
yes, but did you use b-frames? Just because you used divx 5.1.1 doesn't mean that you used b-frames.
I don't know of any sure way to check for B-Frames. I do know that sometimes when you open an avi in Virtual Dub Mod, you see the message "B-Frame decoder lag, nothing to output". Avi's that yield such a message definately have B-Frames, but this is still not a great way to check since not all B-frame AVI's will yield this message! -
lifeisfun,
when you open an avi in Virtual Dub Mod, you see the message "B-Frame decoder lag, nothing to output". Avi's that yield such a message definately have B-Frames,)
But any way is there any way to play Xvid RC1 on this player because I had success with all Xvid codecs except the RC1 version for some reason. Do I need the firmware upgrade or what or can I change the FourCC??? I mean what, can someone help me this time? -
Indeed, B-Frames are not *necessarily* the problem. I have discovered a clip that displays the B-Frame error message in VDubMod, yet plays fine in this player. Unfortunately, though, most AVI's that I have found that contain B-Frames will not play properly in this player. This is most likely because they use other advanced features of the XVID codec.
Actually, it makes a lot of sense that this player can play AVI's that contain B-Frames. It is DivX certified, so it should be able to handle anything that DivX can handle, and DivX does allow for B-Frames.
However, supersonicl2, just because you (and I as well) have found clips with B-Frames that play in this unit does not prove that B-Frames are not at the root of the problem. This is because DivX allows for B-Frames, but not *consequtive* B-Frames. XviD, on the other hand, will allow for consequtive B-Frames. It would surely be helpful, supersonicl2, if you could give us some details on your testing. I presume you encoded an Xvid test clip with B-Frames...but the million dollar question is: what did you set as the "max consequtive BVOPs"? And did you use trellis quantization? Did you use chroma motion? Did you use adaptive quantization? Some of these advanced features may only affect the encoding calculations, but others may actually lead to output which is not compatible with DivX, and that is what we are trying to get at here.
I seriously doubt that changing 4cc will have any affect. This is a DivX certified player, not an XviD certified player. It should play anything that DivX will play, and DivX will play XviD. The firmware surely includes only a DivX Codec. Whether you label your videos as xvid or divx makes no difference...it gets passed to the same decoding codec (DivX). -
Originally Posted by pyrohydra
I then burned another disc in Neo using the UDF/ISO Level 1 format. It read the disc at the same speed as the one burned in ISO. The player had trouble reading about 3 or 4 of the files on there, but DVDinfoPro detected no errors on the disc, so I'm not sure what that could be.
Before I burned those 2 in Nero, I was burning my DVD's in RecordNOW Max in UDF. All of those DVD's read slow (but its not THAT big a deal) and make the player make the chirpy noises. Thankfully, my player has not totally rejected any of my DVD+R's burned in UDF.
Well, thats all. I'll be buying more of these Memorex 8x DVD+R's later... -
How's the playback of the Philips on an HDTV? I'm in the market for a 42" plasma or 50" DLP and was wondering how DivX files look on the larger screen, say 1.4GB movies and 350mb 45min tv captures. TIA
i have a mitsubishi 65" hd tv and the divx looks good, i mean its divx
not dvd quality, you notice pixels in dark and grey areas that you dont
on a smaller screen. the dvd playback on the hd i think sucks
i also have a sony progressive scan that i paid $300 for (dont remember
tha model right now) and its a night and day difference on the hd tv
the philips you notice around the edges of people and objects scan lines
almost like interlaced video and thats there in progressive scan mode
and normal but hey what do you want for the price? it plays divx
i would not recomend it as your only player for a hd bigscreen. -
I agree totally with peterson65 -- I see the same defects in regular DVD playback, and my HDTV is only 32". That is why I have the Phillips 727 to play back dvd, svcd, jpegs, etc....everything that is not divx.
However, the divx playback is awesome, and if you are viewing a high-quality divx (2-cd rip), I think it looks every bit as good as DVD.
So bottom line...just use this player for divx...get another for everything else. Actually I also like the mp3 playback on the 642. -
I agree also, I stated this on the the third page of this thread.
https://www.videohelp.com/forum/viewtopic.php?t=215682&postdays=0&postorder=asc&start=60 -
Originally Posted by CrysDark
I think it's silly to buy this player as your primary machine. Spend the money and get a good quality player for that role (for instance, a nice Panny).
This player should be bought *strictly* for its Divx/Xvid playback which it does superbly (except for QPel videos). -
Originally Posted by FlaveLike a flea circus at a dog show!
Need another Philips USB Divx Player
By s-toon in forum DVD & Blu-ray PlayersReplies: 38Last Post: 21st Apr 2011, 21:12 -
Philips DVP642 vs DVP3560 Which Player plays More File Types
By DJboutit in forum DVD & Blu-ray PlayersReplies: 4Last Post: 3rd Dec 2010, 14:39 -
Remote for Philips DVP642
By Melina in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Jun 2010, 21:54 -
Philips DVP642 DivX subtitles. WORK!!!
By shrybouski in forum DVD & Blu-ray PlayersReplies: 22Last Post: 7th Aug 2007, 14:06 -
Philips DVP642 and DivX 6/Ultra
By cheerful in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Aug 2007, 11:43
