Hi There !!!
As I produce quite a few VCD's I need a good reliable VCD player program on my computer so that I can check things out before going into the lounge room & using my DVD player. I am looking for one that allows FULL SCREEN VIEW as well.
Thanks.![]()
Just a question - sorry for hacking - apoud PowerDVD vcd playback - the audio is always way to quiet - even when I crank up the master and wave volume and my speakers - it's too low. When I play a VCD in MPC or Zoom, the audio is louder (applies to any video actually, not just VCD). However, PowerDVD is best at seeking in VCDs. I use PowerDVD 4.0 XP and I was wondering if there are any settings/registry hacks/program updates that give clearer, louder sound without having to crank up your soundcard and speakers? Thanx.
Hi!
I recommend you to use ZoomPlayer Standard. It's a very powerful player and it's also freeware.
// Znooky
Is divix player good?
By skorpinok in forum Software PlayingReplies: 2Last Post: 7th Aug 2011, 10:52 -
Good PQ DVD Player
By mis3 in forum DVD & Blu-ray PlayersReplies: 24Last Post: 31st Dec 2009, 14:11 -
Looking for a Good Video Player Or DVD Player
By DJboutit in forum Portable VideoReplies: 1Last Post: 6th Jun 2009, 22:57 -
Looking for a Good Backup HDDVD Player??
By ofield1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 17th Mar 2008, 14:01 -
In need of a good DVD Player
By Jenn11803 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 7th Nov 2007, 11:48
