  1. I've been converting all type of files to mpeg without a problem with TMPGENC. But now I have a long divx file XVid and now after I process it I get two files instead of a mpeg file.
    A wav file and a m2v file.
    When I try to join them with the mpeg tool from TMPGENC I get the message:
    Multiplexing linear PCM Stream to system stream is not supported.
    Any idea how can I convert that file to mpeg?????
    Martin - San Francisco
  2. Your authoring program should handle it.. though I don't know why you'd stick to wav. You could always go mp2 if your player supports it
    Dec 2002
    My Swamp
    If you encode to VCD or SVCD you get a mpeg file and if you encode to DVD you gat a .m2v and .wav files.
    DivX and Xvid are two different kinds of AVI .
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    The reason why it is doing it is because you must have had ES (Video+Audio) selected instead of System(Video+Audio). TMPGEnc DVD Author won't have a problem with the two streams though.
    If in doubt, Google it.
