Hi all,
I have problem with 2pass vbr. It run at high qa but not run at highest QA (stop at 50%). I try to go in environment seting, under VFAPI plug-in to change the priority; then I just realize under "NAME" column is mising few names. It do not have: the file can not be loaded, and other names that I do not remember (I don't have my pc on front of me).
Any way, is there any way I can restore the original VFAPI plug-in. So far, I have uninstalled, and have used restore from win xp and still not work. All I remember that I installed Nikon software for my digital camera and it started to have multiple problems. Then I also in installed windv, dvdshrink. So far, I got the reply that windv and dvdshrink has nothing to do with this problem. Need suggestions. Thanks.
My next step is to lower the bitrate from max=8000 to 6000, avg from=6000 to 3000. Maybe it will help.
Results 1 to 1 of 1
How to set MINIMUM bitrate in VBR 2 -pass on TMPGEnc Authoringworks 4
By eltimbomofo in forum Authoring (DVD)Replies: 3Last Post: 9th Mar 2012, 15:59 -
Can someone explain cpu priority to me regarding video processing?
By snafubaby in forum Capturing and VCRReplies: 2Last Post: 19th Mar 2011, 21:43 -
Need to Remove Logo for a set time at a set place.
By Ensign in forum EditingReplies: 3Last Post: 11th Sep 2009, 15:39 -
x264, set quantizer to 10 and vary keyinterval to reach set target bitrate?
By frifox in forum Video ConversionReplies: 6Last Post: 20th Feb 2009, 15:59 -
TmpGenc Authoring Works 4 - how to set bitrate?
By mrhata in forum Authoring (DVD)Replies: 2Last Post: 18th Feb 2009, 00:40
