What are the best settings? Mpeg1, Mpeg2?
I got a 31 minute video and I want to get it on a 700MB CD using the best bitrate possible :-*
thanks
Cheers, Jim
My DVDLab Guides -
You’re going to have to provide more information with what you want to do with the file. Such as are you wanting to make a VCD or SVCD?? if so then there is required bitrate for these formats.
Best quality is SVCD. You can use the Max bitrate for SVCD, since that will fit about 40 minutes per disk (amazing, it's exactly 2x VCD :P ).
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
For a 31 min clip, you need one (1) 650MB CDR.
You encode to SVCD and you use for the video CBR at 2520kb/s and 224kb/s for audio.
An alternative, also could be CVD. Do exactly the same as SVCD (use the same settings) but set the framesize to 352 x 576/480 (SVCD is 480 x 576/480).
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 08:45 -
pc crashes when using tmpge 4.0
By ANTS17 in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 23:55 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 04:55 -
TMPGe and BD template the right settings for pal -getting juttering effect
By millzy in forum Authoring (Blu-ray)Replies: 0Last Post: 31st Jul 2008, 11:13 -
CCE SP 2.67 Advanced Settings (VBR Bias, Quality Precision)
By seven_deuce offsuit in forum DVD RippingReplies: 3Last Post: 11th Mar 2008, 18:30
