Results 1 to 11 of 11
    Oct 2002
    Wisconsin, USA
    I've spent the last hour searching the web for downloadable sound effects either for free or for a "reasonable price". Specifically, what I am looking is stadium crowd noise, boos, cheers, oohs, ahs, and ohs that can occur at a hockey game or a baseball game. I would like to add these effects to home videos I'm working on for my son's and daughter's hockey, baseball, and softball games. (And those that I will be working on this summer). It would be nice if the stadium crowd noise was at least a minute in length or more.
    Everything decent that I found in my search was way out of my price range ($200 to $495.00). I am thinking more like $50 or less.
    Can anybody point me in the right direction or provide me with a link?
    Thank you.
    Vanster
  2. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    You could capture something off TV and rip the audio...
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
  3. on Usenet you can get anything for free ifyou ask in the right newsgroup.
    Also try:
    http://www.partnersinrhyme.com/
    Oct 2002
    Wisconsin, USA
    sacajaweeda,
    I've thought about recording something from the TV. The only problem with that is it's hard to find a sports broadcast where the announcers shut up for more than 5 seconds.
  5. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    cheapest solution -
    go to your local library, see if they have any sound-effects records or cd's. (the BBC Sound Library is a good set).
    if not, next cheapest -
    go to your local computer retailer, or used record shop. sound effect cd's are usually cheap as dirt - most of the ones I've picked up new have been around $10 for a 3-cd set. Used, they can be even cheaper. (the big difference is, if you get it from a computer store, it'll probably be a disc of .wav files instead of audio).
    If all else fails, see if you can get a Kiss or Cheap Trick live lp, there's tons of crowd noise on them you can sample out.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  6. -----------------------------------------------------
    There is a reason why God gave us one mouth and two ears!!!
  7. Link above wrong. Should be http://crowdsoundeffects.com/
  8. Here's one, if you need a longer sound effect then use Audacity to join several clips:
    Jan 2007
    Republic of Texas
    Well, hopefully, SOMEBODY will benefit from the kind efforts of the last 3 folks who posted. As the OP started this thread over 7 years ago, I doubt he/she is still looking.
  10. oops!
