Relative "quality" aside (a lot of that is subjective anyway)- what you've described would be a very nice (and very common) setup for home video work. The Sony / Vegas software is very good. The suggestion from cbkilner about getting a miniDV camcorder with a pass-through to do your A/D conversion is a good one because then in the future all your NEW footage will already be digital- but it's not manadory. You could buy a Canopus, etc. box if you want. I think the latest Screenblast will actually do your basic DVD authoring as well, but I'm not sure of it's limits and / or flexibility.Originally Posted by vwcrusher
Results 31 to 33 of 33
Thanks for the replies,
I am not quite sure why this thread was moved to the Mac forum, but at any rate I do appreciate your suggestions.
I do not do much taping anymore, as my kids are all grown, so that solution is not as attractive. The PC came with the ability to capture directly to MPEG2, but I am questioning whether I should capture to .avi thru a purchased device, thereby acquiring the ability to use Screenblast MS to perform the 'slicker' edits, transitions, etc.
The only question is whether the outgoing quality will be better, the same, or worse than if I continue to capture to MPEG, edit the MPEG file and burn with TMPGenc.
Thanks again[/code] -
I am moving this to the CAPTURE forum, as it seems you got your fix of the info avaliable from the MAC FORUM
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 05:04 -
Capturing VHS to Mac via Panasonic AG-1980 and ATI 650 USB Mac
By Stu187 in forum Capturing and VCRReplies: 3Last Post: 15th Aug 2010, 05:45 -
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 05:18 -
im new to mac... is there a mac program that does what tmpgenc dvd author 4
By ochsfamily in forum MacReplies: 0Last Post: 12th Dec 2009, 22:13
