I've made a film in 30 minutes in premiere 6.0 which I want on a DVD. I'm using DVD-lab for authoring.
But I've have some problem with the exporting from premiere.
I don't have a MPEG codec available directly from premiere.
An uncompressed avi file gets to big (80 GB approxemently)
A Microsoft DV avi-file is almost perfect for my use, but it destroys the films still pictures.
The film is mainly film from DV, which works great together with the Windows DV avi-filetype, but I have some stills which gets crappy when using this codec. What should I do?
PS: I'm using premiere 6.0. PAL. Going to use TMPEG-encoder for mpeg-coding, and DVD-lab for authoring.
Can someone give me a good answer why my stills get crappy with the DV-format?
use adobe MPEG encoder. goto file>export>Adobe MPEG encoder
unless that is only in 6.5.
then jusst select dvd or set all the settings yourself in advanced options. -
Well, the Adobe MPEG Encoder is not available for Premiere 6.0 (I think).
But I found another way. I downloaded the Video Server plugin which makes it possible for Premiere to send information directly to TMPEG Encoder which then generates a MPEG file of great quality!!!
Editing a project in HD, but burning to DVD in SD...
By Huntr777 in forum MacReplies: 6Last Post: 14th Jun 2011, 21:20 -
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 18:08 -
DVD Power Hour Project Help.
By GlockMasta in forum Authoring (DVD)Replies: 3Last Post: 1st May 2009, 07:23 -
Help Neeeded For DVD Project. Extract DVD Menu For Use In Personal Project
By sephiros in forum Authoring (DVD)Replies: 2Last Post: 5th Nov 2008, 13:49 -
DVD Lab Project error
By peterhun in forum Authoring (DVD)Replies: 8Last Post: 8th Jan 2008, 20:35
