hi im trying to create a kvcd using this guide http://kvcd.org/guides/kguide/kvcdguide.htm
I'm having aproblem muxing
please help ive got the encopded video file whoich took me 14 hrs to encode and ive got the encoded audio but when i ty to mux them using bbmpeg after scanning the video it says
Error in MPEG stream at offset (bits) 13: Supposed marker bit not found here's my log
Video: none
Audio: none
Output MPEG information
Video: none
Audio: none
Multiplexing: video and one audio stream
program stream type: VCD
video file: c:\windows\desktop\video.m1v
audio 1 file: c:\windows\desktop\encodedaudio.mp2
program file: temp.mpg
Multiplexing video and audio:
Scanning video stream for a sequence header ...
Scanning video stream for pictures ...
Found 159052 picture headers.
Video stream information
Stream length : 722537733
Total time (seconds) : 5307
Sequence start : 5302
Sequence end : 1
No. Pictures : 159052
No. Groups : 5302
No. I Frames : 5302 avg. size 14055 bytes
No. P Frames : 47716 avg. size 6467 bytes
No. B Frames : 106034 avg. size 3201 bytes
No. D Frames : 0 avg. size 0 bytes
Horizontal size : 352
Vertical size : 240
Aspect ratio : 1.0950
Picture rate : 29.970 frames/sec
Bit rate : variable
Computed avg rate : 136250 bytes/sec (1090000 bits/sec)
Computed max rate : 282400 bytes/sec (2259200 bits/sec)
Vbv buffer size : 40960 bytes
CSPF : 0
Scanning audio stream for access units information
then the error pops up
help please
Results 1 to 1 of 1
Please Help! Muxing for Itunes
By FaiT in forum Newbie / General discussionsReplies: 17Last Post: 24th Mar 2011, 12:20 -
need help muxing to vob
By ChrisDaMan in forum Video ConversionReplies: 8Last Post: 11th Mar 2011, 10:17 -
m4v muxing
By Kurgan71 in forum SubtitleReplies: 6Last Post: 16th Sep 2010, 04:51 -
Muxing to .mpg
By gameroftheuk in forum Newbie / General discussionsReplies: 2Last Post: 18th Aug 2008, 12:38 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48
